Old levelling box advice needed
halloween
Post by halloween »
I have just acquired a pair of rusted drop arms and before I start heating and whacking I need to know how the levelling box goes together...
I have borrowed this image from ebay, its not my own.
I do not have a pin in the slot as shown but instead through a hole roughly at point C
I assume, that part B should slide out of part A and that the threaded bar should unscrew from part B?
Please correct me if I am wrong. :D
lectricman
Re: Old levelling box advice needed
Post by lectricman »
Well, you are correct! :D I don't know what kind of implements would warrant the pin being located in the slot, as it would allow a little movement before the implement lifted. The left link should have an identical slot. I'm working on trying to free up one of my own. It is still showing its bad side right now, but it is pretty rusty. I have managed to get the sliding section apart and have it flipped upside down with PB Blaster soaking inside the hollow tube on the end of the threaded part. Hopefully between that and a little propane wrench action, it will come loose!
1956 Fordson Major Deisel...work in progress
1961 Fordson Super Major...my new favorite
whirly
Post by whirly »
I put my pin in the "B" position when using my flail mower to let it float independent of the left lift arm. The 2" of float at the "B" position gives about 4-6" of float at the end of the link arm. It helps with the large clumps of Guinea Grass I am trying to knock down.
'59 Power Major
Ancient Smurf
lectricman
That makes sense!
The idea of the slotted holes was for wide implements to allow the outer sides to move up and down as the terrain changed.
To get the levelling box apart:
Remove the knuckle. On top of the box there is a lid. remove it with a small screwdriver. Remove the three bolds that holds the lever bearing and remove the lever. Press out the threaded bar. There's a flat bearing on the bottom.
http://people.zeelandnet.nl/hmdetroije
Check the second page at repairs to see the inside of the box.
halloween
Post by halloween »
Thanks for all your replies guys.
The levelling box came apart a little too easily for my liking. On inspection, the thread is very worn and after screwing into the bottom part (B on the picture) for an inch or so it just drops in :( its also bent slightly at the base of the gearbox :cry:
The fixed drop arm is still rusted solid.
Does anyone have a replacement threaded rod/gear and part B for a levelling box they want to sell ??
The levelling box can be bought new. Check out is it's available in parts at http://www.agrilineproducts.com/partsca ... major.html or another supplier.
halloween
Post by halloween »
Thanks Henk, I knew about Agriline, but just wanted to try and avoid paying €221.40 + delivery for a pair of drop arms. I only paid €1300 for the tractor!
I understand.
Moost of the time I try to buy them second hand or repair them.
curtsat15
Post by curtsat15 »
Or if you're in North America, you could try these guys: http://www.importtractorparts.net/fordson.html
About $160 US.
