Oil Filter housing assembly question
Posted: Fri Jun 29, 2012 9:17 am
by Jm-baker
I have a 1952 Fordson Major Diesel.
I took the oil filter out yesterday and it seems to me that it was not installed correctly or a part is missing. I have the housing cylinder, long bolt that goes through the assembly and a spring.
I can't see how the oil filter seals at the bottom around the bolt shaft, is there a piece missing that would go on the spring?
If anyone has a diagram or explanation or photo of how the filter assembly goes together i would appreciate it.
Re: Oil Filter housing assembly question
Posted: Fri Jun 29, 2012 12:55 pm
by Jm-baker
http://www.fordsontractorpages.nl/phpbb ... ring#p9439
Found this, very helpful, looks like im missing the parts between the filter and spring.
Does anyone know where i might get items 19 and 20 from the right image.
http://sites.google.com/site/fordsonsit ... edirects=0
10631-H (metal washer above spring)
10609-H (seal top and bottom of filter)
I am in the UK
Thanks !
Posted: Fri Jun 29, 2012 2:03 pm
by Gman
Hi Jim, there are parts manuals on the home page of this site, I beleive shows all parts. I also go to New Holland web site and look at parts there, there are great printouts of parts there. Look up fordson and you will get a choice to which year you have, lots of good info there with part numbers. I print out the parts I need and go to local new holland store and they can usually get what I need. I believe if you have a '52 then it will be the longer filter. Good luck.
Posted: Fri Jun 29, 2012 5:04 pm
by super6954
the parts that are missing are not available new I looked on the ford parts site the other day for Colobio, you either have to find used or make the parts up. There are a couple of different styles of filter. some parts do not inter change. If you are not needing to keep the tractor original you could by a complete used unit, There are 2 types of filter long or short. You should have the long type.
Colobio has a post on here maybe a month ago from when he made up his missing parts it has pretty good pictures of what he did.
Posted: Sun Jul 01, 2012 4:25 pm
by Jm-baker
Thanks guys, I will make one up.
