FSM Hydraulic set up
theseeker905
Post by theseeker905 »
Apologies if this is elsewhere on the site, but I am going to drop the top back on tomorrow and need to be sure of setting.
Have used photos from another thread
Am I right in thinking for Qualitrol setting it is 13mm from the stop shown marked in the picture below
And for position it is with the lever right down in the quadrant
Thanks in advance
theseeker905
Re: FSM Hydraulic set up
No. The stop is the little tab in the quadrant at the end of the slot. You have marked the flow control actuator.
theseeker905
Thanks Brian.
for Qualitrol I have set it from the tab
and for position have set it with the lever at the bottom, as the 2nd photo
Thanks for your advice....
theseeker905
Thanks Brian.
