Seal advice please
halloween
Seal advice please
Post by halloween »
This is the housing which supports the two shafts, drive and PTO as they enter the dual clutch
and this is the outer of the shafts which go through the housing above and engages the first of the discs in the clutch
I can see that there is a large seal in the housing, but can anyone give me the size of it and any other seals which may be in the two shaft assembly as there has been quite a bit of oil getting in to the clutch that way. I have the NH diagram showing the 07A02 front transmission internal layout, but that seems to be a single shaft.
Gman
Re: Seal advice please
Post by Gman »
Hi again. Try going to New Holland web site, it has most parts listed for the Fordsons. I use it, print out the parts I need and go to local store, sometime they have to order more items than I need, like a pack of five and I only need one so I then go to Messicks New Holland site and order from them. Good luck.
Gman: 1959 Power Major
BearCreek Majors
Post by BearCreek Majors »
The large seal in the back of the housing should be a E88=GE-9, the inner seal should be a E1ADDN-7052A.
I have replaced the inner one with a “off the shelf” seal that was close…..didn’t work for crap, New Holland still had them available a year ago and the price was reasonable.
Pat
halloween
Post by halloween »
Thanks Pat, I've emailed the NH dealer and will see what they say.
halloween
Post by halloween »
Just heard back, €15 each seal and €3 postage! Happy!! :clap:
