Bit too heavy!
Re: Bit too heavy!
good photo
that crane looks good does that power off your tipper pipe.
- Contact:
Re: Bit too heavy!
Impressive.
You will have to watch your back as the crane arm will punch in your back.
Re: Bit too heavy!
Jib all the way in and with the linkage in the fully raised position does provide a lumber support! The short jib/heavy lift option will be for jobs like stump pulling, I imagine. Not really practical for lifting and placing loads.
Re: Bit too heavy!
HiAdrianNPMajor wrote:Jib all the way in and with the linkage in the fully raised position does provide a lumber support! The short jib/heavy lift option will be for jobs like stump pulling, I imagine. Not really practical for lifting and placing loads.
After seeing a guy near killed when a mounted fork lift sheared the linkage on a major I would be very carefull weighting the front and picking up a big load. The week link right now is the front coming up and giving the warning
If you ballast more the next week point will be the linkage and there many not be a warning only a load bang if something goes wrong, and hopefully nobodys hurt or killed. There are huge forces involved in what your doing and the major linkage is not that strong. The health and safety might have something to say about it too if something happens
it's a great piece of engineering but please be carefull using it
Re: Bit too heavy!
Good points Robert and well taken. Thanks for the heads-up.
Best wishes
Adrian
Best wishes
Adrian
