lift capacity
Posted: Sun Nov 11, 2012 11:33 am
				This could be a dexta or major  question,  the  dexta rated lift capacity is 1840lb,
is the major the same or would it be able to lift more because of its extra weight,
i have done a search here and also goolged this with out an answer including tractor data
maybe someone could clear this up.i know the easy answer is, if it will lift until the front comes off the ground
then it is too heavy but is there a known rated lift weight
 . sky blue
