				crankshaft locking tabs. question
				Posted: Mon Nov 19, 2012 7:19 pm
				by thestig246
				Hello all, progress has been abit steady on my engine, but have now got the right thurst and bearing on the crank the problem now is some of the locking tabs that hammer up against the bolt heads are snapped at the edges..
 (they have been on and off a few times..)
SO the question is can new ones be sourced??
one of my older mates had a look and he just said "it'll be alright"... if the bolts arnt tight the tabs wont stop it anyway...
any advice would be great
regaurds dan.
				Re: crankshaft locking tabs. question
				Posted: Mon Nov 19, 2012 8:14 pm
				by AdrianNPMajor
				Locking tabs are not designed to be re-used.  They are available to buy and easy to make.  Given all the hard work you've put in to get to this stage, you owe it to yourself to fit new ones.
Best wishes
Adrian
ps Photos please of your hard work!
				Posted: Tue Nov 20, 2012 10:33 pm
				by thestig246
				yeah i would like todo it all properly, but where can i get some of these locking tabs from i have looked everywhere
				Posted: Tue Nov 20, 2012 10:53 pm
				by Aussie Frank
				Hi Dan,
If you can find out the original Ford part number try entering it in the search function at the Sparex web site. I did that when I was looking for locking tabs for my E27N P6 and it came up with a hit on a Sparex replacement.
If you can't find the part number measure the hole diameter and the length and I can check it against the Sparex ones I have at home to see if they would fit.
Regards, Frank.
				Posted: Wed Nov 21, 2012 8:49 pm
				by thestig246
				many thanks , had a good look through but had no joy
i have a freind who has a cnc plasma cutter its becomming more tempting to get him to wizz me some out on there
 , but would rather use the genuine parts
 (if they were availible
best wishes
dan.
				Posted: Thu Nov 22, 2012 8:43 pm
				by Emiel
				Hi Dan,
You mean these ones?
regards
				Posted: Thu Nov 22, 2012 10:36 pm
				by thestig246
				yeah!! those are the ones Emiel
where did you get those from sir??
many thanks
				Posted: Fri Nov 23, 2012 12:26 am
				by halloween
				Posted: Fri Nov 23, 2012 2:11 am
				by BearCreek Majors
				These guys look like they have a few of the hard to find parts, one of the few vendors that have the correct three point leveling boxes for the Super Majors.
Pat
				Posted: Fri Nov 23, 2012 3:14 pm
				by fnoller
				BearCreek Majors wrote:These guys look like they have a few of the hard to find parts, one of the few vendors that have the correct three point leveling boxes for the Super Majors.
Pat
Yeah!!!
  im just missing the leveling box for my super....
Is it just me or are we missing a link in this forum were people could share sites likes this
 , some websites cant be found by googling on specific parts
And if i were really lucky some of the shared sites got the yoke im missing in the draft unit
				Posted: Fri Nov 23, 2012 5:03 pm
				by Pavel
				This mob stock a huge and varied variety of lock washers --
www.seastrom-mfg.com/seastrom...herSearch.aspx
In the past when stuck for strip washers I've made some from slotted angle. In the UK I believe it's called Dexion.
Pavel
				Posted: Sat Nov 24, 2012 12:19 am
				by BearCreek Majors
				Posted: Mon Nov 26, 2012 4:38 pm
				by fnoller
Its for at New Performance im looking for
