Injection pump Minimec
Posted: Tue Dec 11, 2012 7:54 pm
				Hej!
Are there someone who now if the minimec diesel injection pump is used on the super major engine in different versions?
Are there differences between minimec injection pump in agriculture applications compared to other application using the same Fordson Super major engine?
My question is based on this experience. I have a Super Major -64. It is in a normal shape for being used for some thousand hours. In other words the engine is not perfect but OK. Easy to start and no problematic oil consumption etc.
It has been equipped with a minimec injection pump that originally comes from some other application. There are traces of yellow paint and it has no “power take of” for tacometer cable. Instead there is a bigger drive shaft with splines. So the pump has some time before my ownership of the tractor been replaced.
When using the tractor the regulator has a rather week reaction to increased workloads. If I compensate with the throttle level the engine responds OK but if I don’t compensate the rpm is rather reduced even by minor increases of the load. It also don’t have the typical torque top at 1200 rpm. “So it behaves not relay like at tractor”.
I have borrowed and used a nother injection pump for a while and the performance of the tractor is better. So the problem is obviously influenced by the injection pump. So my question is: Is the difference in performance a result of different models of the injection pump? Or is it caused by differences in the actual conditions of each pump? (The borrowed one is recently overhauled by professional diesel mechanic. )
It would be great if someone could give some information about this so I know if a possible solution could be to overhaul my “non agriculture pump”.
