Can anyone help i am about to change the clutch and brake x shaft bushes as the shaft was leaking oil past bush and out through the seal, My problems is that i have new bushes from agriline which are the correct length but if you mirror them up against the old ones that I have removed, the old ones have a slot which runs down the entire length of the bush. I presume the slot is for expansion while the bush is being fitted
Therfore do cut a new slot in my new bushes and fit, and will the still require a ream.
Please can anyone advise oh i have not split the Tractor
David
						Clutch and Brake x shaft bushes
Re: Clutch and Brake x shaft bushes
taff866 wrote:Hi
David
[b][/b] See how hard they are to drive in, If they are to tight I'd be inclined to give the outside a light touch on a belt grinder, wouldn't cut a slot in them  unless
it is unavoidable. Hard to know if they will need reaming until they are fitted.
