minimec query
minimec query
was the minimec pump fitted to super majors 63/64 fitted to any other tractors ?  or was it just made for the super major ?!
						Re: minimec query
Very interesting question, and hopefully someone ca contribute
						Re: minimec query
indeed it is - I have seen similar injector pumps on David browns & some jcb machines - but they are certain not the same pump - but tracking a minimec  pump is hard - let alone not knowing if it was on some thing othe that a super major !
Re: minimec query
There should be a tag and ID/ Serial numbers on every pump made. A good pump shop should have the info as the pumps need to be calibrated to manufactures specifications. Also with these numbers you should beable to look up what the pump was originally intended for. Dandy Dave!
Re: minimec query
HiMjg1705 wrote:was the minimec pump fitted to super majors 63/64 fitted to any other tractors ? or was it just made for the super major ?!
I wonder if you will find that pump was used on the early Ebro copy tractors from Spain that had the Super Major engine fitted. The only other place i think you might find it may be in a machine that used a Fordson Super Major engine or skid as a drive unit .
There are a lot of similar looking pumps out there that may share some components. But i'm thinking the front pump mounting lug might be unique to that style Fordson motor .
Both mountings are quite different to the vacuum governor pumps on earlier tractors they might match something else easier with 4 bolts in the base.
I just also thought about if the last true Ford 4 d truck motor had this pump before the change in the mid 60's to the timing case mounted pump
Maybe our ford truck guys could tell us
						Re: minimec query
Thanks guys
 this seems to cure my curiosity as to the fitting of minimec pumps ! I can now rest in peace
 thanks, Michael.
