I am posting this for James.
Pat
I have had the transmission out to do a few jobs. One of which was to replace hanbrake that was virtually scrap. trouble is it wasnt physically possible to get the seven fixed plates installed, i couls only manage 5 plates so there was still a gap between plates when it was assembled. How much gap did you have when yours was up? Also is it possible for you to push yours along the ground by hand or do you have some resistance through the box?
james
						Hand Brake
				BearCreek Majors
				BearCreek Majors
Re: Hand Brake
James, I’m thinking you have the assembly incorrect, one of the fixed plates needs to be installed before the idler gear, as per the instructions in the left column of the attachment.  Warped plates would most likely cause the same issue, I installed all new ones in my 54.
Pat
						Pat
Re: Hand Brake
Thanks.
new plaes fitted.
Fixed plate first,
gear
fixed plate
splined plate
fixed plate
splined plate
fixed plate
splined plate
fixed cover plate
spring
nut
Plates are 2mm thick??
						new plaes fitted.
Fixed plate first,
gear
fixed plate
splined plate
fixed plate
splined plate
fixed plate
splined plate
fixed cover plate
spring
nut
Re: Hand Brake
lookling at that picture your spring is far more compressed than mine which was a new replacement. that would explain why i couldnt get as many plates
