pump drive repair kit
Posted: Fri May 31, 2013 2:59 pm
by Mjg1705
i am going to need to buy a repair kit for the drive shaft from the injector pump to oil pump/timing gear. this includes the bearings and the seal. my only problem is that all repair kits i come across say that they are for simms pneumatic pumps- would this work on my engine with the miniec pump !? does at actually matter as surely it makes no differance as its the bearings/seal sit in the engine block casting and aint nothing to do with the pump !? :scratchhead:
Re: pump drive repair kit
Posted: Fri May 31, 2013 5:03 pm
by Fixersteve
Hi MJG, I used the Agriline injection pump bearing and seal kit for my minimec pump and its fine.
So glad you got your crank problem sorted :beer:
All the best
Steve
Posted: Fri May 31, 2013 5:11 pm
by Mjg1705
Thanks Steve - I will buy that one then ! Ha yes thank god - got pitons in today and crank still turns ! So must be good ! :D
Regards,mike
Posted: Mon Feb 02, 2026 5:43 pm
by Billy26F5
Bearings were always an RLS-7 at the front and a 6204 at the back, remember the seal must be the full width. When we got Agriline's kit it only had two 6204 bearings and a half thickness seal. They also sell a strange bearing, that approximates itself to an RLS-7 in metric approximations. Stay well clear from it. It's loose on the auxiliary shaft and tight in the block. Neither bearing must be sealed.
