Super major hydraulics
Posted: Wed Jun 05, 2013 9:14 pm
				Hi guys I'm new here! I have 2 majors, a mk2 diesel and recently acquired late super major, one of the first with the mimec pump!
My problem is the hydraulics on the super, I have just replaced cross shaft bushes, cross shaft and piston seal, reset all the linkage as per the manual, but, when in position control they rise, come to a neutral point for a brief second and then you hear the pump working hard and pumping all the time to maintain the height. I suspect a valve but which? Also the flow control knob sometimes makes a difference with the speed of the hydraulics, but it's very hit and miss, in some positions it's faster, move it further on and the hydraulics stop completely?
Slightly confused and would be greatfull for any help!
Matt
Matt
