    I seem to  think the problem with the agriline kit comes more when you have one of the loaders from the U.S.A that came as part of a back hoe package. I  think someone posted a picture here a while ago of a regular loader and an add on kit
  you might have to modify the pump mount very slightly. as it fits at the bottom on the frame rail  instead of on the top under the bonnet like the original. Don't hold me to any of the above it needs checking to be 100% sure , I read way to many forums and pages to remember exactly
 Are all your king pin bushings, stub axle thrust bearings, and the bushings and pins all good on the tie rod. I have seen the ware in the tie rod throw the tracking out, that can make the steering heavy as the wheels toe out or in. The one I drove like it steered perfect in reverse but was hard in forward as the toe setting went  wrong going forward
  The spindle thrust bearings can wear fall apart/ or seize and don't take grease as the grease pumps out the top but doesn't go to the bearing with the weight on the axle .
 Tyres can also affect the steering drag. wide used car tyres on 16" rims are bad you really need good tread, 8 ply + if available ( for load rating)  3 rib (Maybe a 4 rib  on a 16 " steel rim)  tractor front  tyres on your rims to get the best out of it too with a loader
 . Cast 3 or 4 spokes make it heavier to steer as well due to weight of centers from what guys have said.
 I've also seen the spindles seize in the axle bushes  if not badly worn ,the petrol Major  and loader I bought was seized near solid, and to the point of breaking the steering box
 you really have to check this lot out and get that all right , as it all causes steering problems if worn out/ seized up
 I had a customer that used a power major with loader and his would not steer picking up a full half ton feed sack. I re built the front axle completely
The guy could not believe the difference it made. Yeah you could not spin it with one hand, but it did atleast steer 90% better with out power steering
