Does anyone know the thread size of the large bolt that holds the crankshaft pulley on ? The head of the bolt takes the starting handle.
My thread is damaged inside the end of the crank and I need to run a Tap down it.
Its a Fordson Major, not sure exactly which year but it has the throttle linkage that goes through the block.
Any help will be much appreciated
Paul
						Crankshaft Pulley Thread
Re: Crankshaft Pulley Thread
Good morning
Sadly, the parts list does not detail the thread size of the front crankshaft "bolt", as it is not a standard fastener. I would take your long crankshaft bolt to a good fastener supplier, or engine reconditioning shop and they will use a thread gauge to tell you what it is.
Tim
Tim
