Where to buy new solenoid?
Posted: Mon Mar 17, 2014 7:06 pm
by SimonT
Hello.
When I am starting the engine on my newly acquired Power Major this thing (which I told is probably the solenoid) gives off quantities of thick electrical smelling smoke. I am told it is on the way out. Any idea how/where I buy another? I am in the UK.
Also, what do you think the last owner stuck that thin plastic tape behind it? Is it a clue to the problem?
Thanks for any help.
Simon
Re: Where to buy new solenoid?
Posted: Tue Mar 18, 2014 12:07 am
by Daves rusty bits
Simon, your solenoid looks a different type to mine, but it appears on the way out judging from the black melty looking patch on it. When mine failed it nearly ruined the starter by keeping it spinning after the engine had started. Google power major solenoid and you should get plenty of results.I bought one for a classic BMC mini and it was an exact replacement at half the price of some online shops. I expect someone here can say if the 2 different type of solenoids are interchangeable
Posted: Tue Mar 18, 2014 12:18 am
by SimonT
Thanks for this Dave. A bit of a shame as I've left it standing in the middle of the garden. Looks like it'll be there for a few days longer. Better apologise to the wife.
Posted: Tue Mar 18, 2014 2:17 am
by oehrick
Simon
My Sol is like Daves, as a get you home method you can short across the heavy current contacts after having pushed down the start lever to engage the pinion, (I use a spanner thats no longer needed) I cant see if you could do this with yours but if you try, don't get your fingers near because of the heat / flash, ditto no metal watchband etc. which might ground (DC burns are nasty) and as you're under the tank, nothing that might catch fire and
ALWAYS MAKE DOUBLY SURE ITS OUT OF GEAR AND FOR GOOD MEASURE HAUL THE HANDBRAKE HARD ON
HTH get it out of the garden
Posted: Tue Mar 18, 2014 9:23 pm
by SimonT
Hahaha. Thanks.
When the solenoid smoked the battery was not well charged. I've since charged it and today the tractor started just fine. No smoke at all.
Flummoxed.
Posted: Wed Mar 19, 2014 2:37 pm
by Pavel
It started -- nice one!
But may I suggest you have a go at the wiring and connections to the solenoid. They look very close to the solenoid body, which could cause a short.
Pavel
Posted: Wed Mar 19, 2014 6:09 pm
by SimonT
Thanks Pavel. I will.
Maybe this is the reason the previous owner stuck that grey tape on it.
Posted: Thu Mar 20, 2014 2:42 pm
by Pavel
Not too sure how far you are wanting to go as far as renovating your electrical wiring but the insulation of the yellow with red tracer wire, which feeds the ignition/light switch, appears slightly twisted and swollen which is an indication of excessive current flow possibly caused by the intermittent short at the solenoid.
Pavel
Posted: Fri Mar 21, 2014 3:08 pm
by Dandy Dave
I would not play around with that Solenoid. It has been hot and compromised. I would replace it. Also, It looks like the wire on the other side has broken strands. It is very important that all the electrical wires and connections are in good condition. It takes a lot of amps to spin the diesel. Any bad, or heated connections lead to a loss of current. Also, it could lead to burning out your starter. I found several links in the other thread that show what you need for a solenoid. Dandy Dave!
Posted: Fri Mar 21, 2014 4:00 pm
by Matt in WI
Simon,
I have to agree with Dave,
Please do not mess about with that solenoid. It has clearly been hot and could cause a short. Much better to not risk it and get a new one. Any "simple" solenoid should do, check with your local auto parts suppler.
Posted: Fri Mar 21, 2014 4:01 pm
by Bensdexta
Dandy Dave wrote:Also, it could lead to burning out your starter. I found several links in the other thread that show what you need for a solenoid. Dandy Dave!
Would that be if the solonoid fails to break the circuit and keeps the starter turning after engine starts....?
Posted: Fri Mar 21, 2014 4:36 pm
by Matt in WI
Ben, The solenoid would not break the circuit as you said and the starter motor continues to run, a rite good way to burn one up for sure.
Posted: Fri Mar 21, 2014 8:52 pm
by SimonT
OK. Advice taken. I'll get a new solenoid. Thanks.
Posted: Fri Mar 21, 2014 8:59 pm
by SimonT
Dave. Which thread are you referring to? There only one link in my 'dumb battery' thread and it's to a solenoid that is only available in the US (I'm in the UK).
Posted: Fri Mar 21, 2014 9:09 pm
by SimonT
Posted: Sat Mar 22, 2014 1:14 pm
by Dandy Dave
Yup. That is it. I just put the links out there to show you what it should be. Dandy Dave!
Posted: Wed Apr 16, 2014 9:38 am
by 1su9pm6aj4
Seems a battery cutoff switch might be a good idea for the possibility of a solenoid going bad as described above.
kerry
Posted: Wed Apr 16, 2014 1:46 pm
by Dandy Dave
It is not a bad thing to have a main disconnect switch on our older Equipment with iffy wiring. Dandy Dave!
Posted: Thu May 01, 2014 2:34 pm
by SimonT
Hello again.
I've just changed my solenoid. However one of the wires has become disconnected and I've no idea where it goes. It's the other end of the wire fitted to the non-battery terminal (i.e. fitted to the rhs of the body of the solenoid).The Fordson wiring diagram is a little confusing as it only shows one wire fixed to this position (blue-black tracer) whereas my Fordson (bereft of lights) has two wires connected here, a red one and a grey one with blue sheath.
http://www.fordsontractorpages.nl/manua ... 14-115.jpg
I'm hoping that the loose wire should be connected to the "Mechanical Switch Actuated by Movement of Pinion Control Lever". As the wire terminates in a spade connector and is covered in oil/grease this seems likely.
Can anyone tell me where the "Mechanical Switch Actuated by Movement of Pinion Control Lever" is situated?
As ever, help is very much appreciated.
Thanks.
Simon
Posted: Thu May 01, 2014 4:59 pm
by Pavel
Underneath the rubber gaiter on top of the starter motor. This switch has a Red wire from the ignition switch, and a Black with Blue tracer [not blue with black] from it to the starter solenoid.
If your disconnected wire is, as you suspect, the one to the starter motor switch, then the starter will not operate without it being connected.
Also a little confusing is the colour of the wire in your pic [yellow with red tracer] as this is shown in the wiring diagram you are using as being that from A1 of the regulator to the ignition switch -- but used in later models for the circuit you are concerned with. I would urge checking, and double checking, by using your multi-meter to be sure of continuity.
Pavel
Posted: Sat May 03, 2014 6:07 am
by SimonT
Thanks Pavel. Unfortunately the wiring on my Power Major appears to have little in common with that shown on the diagram.
The wires are different colours and the diagram does not seem to include the cooler fan and the ignition switch! I think you are right and I need to get serious with a multimeter! :-[
And have discovered this mess by the ignition switch. From bad to worse.
Posted: Sat May 03, 2014 4:00 pm
by Pavel
Not sure, Simon, what you mean by the "cooler fan', unless you have an electric fan fitted in place of the blades on the water pump. The ignition switch is the large circle on the bottom of the diagram, slightly left of centre, with the words "side, tail, aux, head, bat. & coil" printed in it.
I rather think that, like my FMD, you need to re-wire just about all of it. If you do decide to re-wire I suggest taking digital photos of all wire connections to switches and units before disconnecting the old wires as a handy reference for when replacing with new.
Pavel
Posted: Sat May 03, 2014 10:59 pm
by Roadless63
one thing to look for that may have caused your solenoid to burn out is a sticky switch on the starter. When you push the starter lever it activates a small switch on top of the starter to complete the solenoid circuit. Sometimes the plunger gets sticky and doesnt pop out when you let go of the lever. With the engine running you may not hear the starter whirring away to itself, after a while the coil in the solenoid can get quite hot. Worth checking once your new solenoid is up and running.
