Currently wiring my power major and although I have the diagram the power comes to the solenoid but the engine won't turn I have tried both positive and negitive earth and still no luck any help/photos to show
Robert
Power major wiring
Re: Power major wiring
If the starter turns, but not the engine, it may be that, whilst your wiring circuitry is spot on, the starter pre-engagement mechanism is not allowing the pinion drive to mesh with the ring-gear. The linkage can be adjusted to affect this. If this is not the case, come again with a little more info.
