Serial #: 1578236 That makes her the 2,350th Super Major built
Engine: N7D: Nov. 7, 1960
Gearbox: M31D: Oct. 31, 1960
Rear axle tubes: N9D: Nov. 9, 1960
Hydraulic cover: N2D: Nov. 2, 1960
$1100. Not a bad deal if you ask me, considering that wore out junkers are typically around $1800-$2000 locally. I put a cheap set of gauges on it yesterday to keep an eye on the vitals since the originals aren't hooked up. Oil pressure when hot is around 10 psi at idle and 20 psi at half throttle with the old oil still in it. I think it might have a bad head gasket, though. I noticed a lot of condensation and steam coming out of the oil fill after it had run for awhile. So I changed the oil; the old oil looked like it had been in there since 1960 anyway. I also drained and refilled the radiator with fresh water. Today it will get a new fuel filter and fresh fuel.Bensdexta wrote:How much may we ask?
Great find
That is my three point lifting boom. I put it on to try and free up the hydraulics, as they were stuck in the up position. It has since been moved to the proper location on the yoke.AdrianNPMajor wrote: What's the attachment on the three point linkage? And is it attached directly to the draft control yoke? If so, it needs to be attached to the pin below, and if the attachment is not one that needs draft control, then two pins need to be inserted to save the draft control mechanism from forces it's not designed to take.
I have no idea! The guy I bought it from said that it is exactly the way it was when he got it. He intended to restore it and just never got around to it. Lucky me!AdrianNPMajor wrote:Love the faded orange colour. What's the story behind this?
Thanks for the diagnosis! Now I have something to tell the wife when she asks why I need two tractors! As far as the seat, I don't know. This is the first one I've seen with that type of seat. I do enjoy the taller stance, though, as I am 6'5'!oehrick wrote:Congrats on a great addition to the squad![]()
MAD is the medical term, Major Aquisition Disease - once caught its incurable![]()
The non-hydraulics pattern seat looks odd to me - were they a common fitment or has this been grafted from elsewhere d'ya think?
Look forward to hearing more as you explore............
I'm in Hernando County, about 45 miles north of Tampa. I have a lot of family in Wisconsin that I've never met. Mostly in and around Slinger. I'm sure you've heard of Wolf's Head motor oil, right? Family company.BearCreek Majors wrote:What part of Fla are you at, I lived over in Dixie county for a while when I was a kid.
Pat
Why Tractors are Better than Womenlectricman wrote: I just hope the other one doesn't get jealous!
.neilarmo wrote:Why Tractors are Better than Womenlectricman wrote: I just hope the other one doesn't get jealous!
You can ride on a tractor any time of the month.
Tractors don't have parents.
You can share your tractor with friends.
If your tractor makes too much noise, you can buy a muffler.
If your tractor smokes, you can do something about it.
If you smoke, your tractor doesn't care.
Tractors don't whine unless something is really wrong.
Tractors don't care how many other tractors you have been on.
Tractors don't care if you look at other tractors or if you buy tractor magazines.
Tractors don't care how many other tractors you have.
If your tractor is too loose, you can tighten it.
You can have a beer while riding on your tractor.
You can have a different color tractor and show it to your parents.
You don't have to be jealous of the guy working on your tractor.
You don't deal with priests or blood tests when registering your tractor.
If you say bad things to your tractor, you don't have to apologize before you can ride again.
You can ride on your tractor as much as you want and it won't get sore.
Your parents don't keep in touch with your old tractors after you dump them.
Tractors always feel like going for a ride.
Tractors don't insult you if you're a bad driver.
Your tractor never wants a night out alone with other tractors.
Tractors don't care if you're late.
You don't have to take a shower before driving your tractor.
It's always O.K. to use tie-downs on your tractor.
If your tractor doesn't look good, you can paint it or buy new parts.
You can't get diseases from riding on other tractors.
Tractors’ curves never sag.
Tractors last longer.
Tractors never get pregnant.
On your tractor, you can control the speed and time of arrival.
Thanks Robert, I knew it was getting towards an 'off topic' post but I hoped the mods would see it as relevant to the OP.super6954 wrote:Hi neilarmo
looks like the moderators and members on this forum have a better sense of humor, than some of the ones on yesterdays tractor forumsIf you posted this on there somebody would of whined how offensive it was to women, and got it removed by now, and probably you banned from the forums as well
Got way to many highly religious guys down there on that forum, with no sense of humor on some of the boards![]()
Thanks for posting is pretty funny and all in the mind, guess some minds are a little more crooked round here![]()
