Driver Seat
Dietmar
Driver Seat
Post by Dietmar »
I am looking for a more comfortable seat as the pan type.
Does anybody have a newer version installed which can be recommended?
The Major with Hydraulics is kind of tricky as the space is limited aft and it is already on the high side.
Best regards from Austria
Dietmar
jan
Post by jan »
Hi Dietmar
Werde am Wochenende ein paar Fotos von meinen Sitz machen.
Wenn du mir deine email-adresse gibst,sende ich sie dir gerne zu.
Habe einen etwas älteren Grammer-Sitz (schön aus Blech/ohne
Plastik,aber voll einstellbare Fegerung)auf meinen Super Major.
Ich hoffe damit helfen zu können.
mbg Jan
Mike Kuscher
Post by Mike Kuscher »
Hi Jan,
Sehr interessant. Ich habe auch ein Major und mit meiner Rückseite auch leiden. Möglicherweise konnten Sie die Abbildungen auf diesem Aufstellungsort für uns alle bekanntgeben, um zu sehen. Es kann meine Antwort auch sein.
Viel Dank
Mike
so the rest can follow...
Very interesting. I too have a Major and also suffer with my back.
Maybe you could post the pictures on this site for us all to see. It may be my answer also.
Frans
Post by Frans »
Hello Jan Dietmar and Mike,
Here a picture of my super major with a new seat, they are for sale at the new holland dealer
for the power major I have the same seat in blue I've bought that abouth 6 years ago for my dexta but the dextas are solf without the seat
regards Frans
1964 NP Super Major
jan
Post by jan »
hi
here are the pics,hope it works.
it`s the seat that is on my FSM (1617909)
the cushion was removed for pics
it`s a verx good seat when you have trouble with your
back,the suspension is adjustebl
but remeber,it`s not original
was made by Grammer,a german company,in the mid
seventies,i think
mbg jan
Dietmar
Post by Dietmar »
Thank you for the great pictures.
The issue I have in front of me looks different.
Frans version looks like it has no Hydraulics, which makes mounting easier as it fits lower on a flat surface.
Jan, yours is a Super Major which has a different Hydraulics as well.
The mounting points on the pre Super are lower in front of the arm housing - this makes it complicated. The hydraulic arm housing sticks up and limits any construction to be moved back to it.
If I mount a regular seat on this provisions it is to far forward.
It looks that the only way to mount it right is using the original pan.
Maybe someone has an additional idea.
Dietmar
