				Steering box
				Posted: Tue Jun 09, 2015 1:52 pm
				by Dazo1960
				I am using 20.50w in engine,gearbox and back end what oil for steering box 1960 fm cheers darryl
				Re: Steering box
				Posted: Tue Jun 09, 2015 2:52 pm
				by Pavel
				The good book states SAE 90 -- which is what I use.
Pavel
				Re: Steering box
				Posted: Tue Jun 09, 2015 5:27 pm
				by Dazo1960
				Cheers pavel
				Major Steering Box (serious Wear?)
				Posted: Sun Jul 24, 2016 9:01 pm
				by billy
				Finally I managed to take the steering wheel off, had to destroy it in the process but...it off!
So I began to strip it down, and once the oil was out and the shaft out, I started to see bad things...
Then I looked at the worm gear...this wear looks bad, what are other peoples thoughts?
Then in the assembly nut has a fair amount of wear.
Also the top bushing is worn...anyone know where I can get a knew one from??
Cheers in advance!!
				Re: Steering box
				Posted: Tue Jul 26, 2016 9:05 am
				Billy that is the worst worn steering box I have ever seen!
  Think you need to visit some breakers or e-bay.
				Re: Steering box
				Posted: Wed Jul 27, 2016 2:36 pm
				by RH
				I have one on a FSM that may look like that.......it snaps, crackles and pops when turning.  Sounds quite arthritic.
Be a winters job though!
				Re: Steering box
				Posted: Wed Jul 27, 2016 3:13 pm
				by billy
				Well that's not what I wanted to hear!
 but oh well!
The strange this is the steering was lovely, I couldn't feel any grinding or anything, I was surprised it's this bad, she feel smooth when turning. I only stripped it down to replace the seal on the drop arm...
In a humorous mood I thought about getting the worm gear welded, then I thought maybe that could work...what's people's thoughts on that???
				Re: Steering box
				Posted: Tue Aug 23, 2016 10:08 pm
				by paudie
				That was as bad a steering box as I've ever seen, considering it was full of oil!. I'd say it's beyond salvage
				Re: Steering box
				Posted: Tue Aug 23, 2016 11:22 pm
				by oehrick
				Its not in the 'good book' but you probably need 25% by volume of sawdust with the sae 90 until you find a replacement - was there much backlash in the steering ? if not it speaks volumes for the chap who designed it and the main reason for changing from worm and nut to recirculating ball boxes - happy hunting
