				Buying Bits
				Posted: Fri Nov 06, 2015 10:20 pm
				by billy
				Hello Chaps,
Have any of you bought a cam thrust washer, one that is round (not horseshoe). I have spent hours searching the web, found nothing. Has anybody out there know where to get them, or even got one I could by?
If not, could I use a horseshoe one? As a last resort?
				Re: Buying Bits
				Posted: Sat Nov 07, 2015 10:31 am
				The Major did not use a round thrust washer it was always Horseshoe. You would not get a round one over the camshaft or over the gear hub. Some Majors may have been fitted with the later single bolt fixing cam shaft but these will also have been fitted with a new front plate with a thrust area on the plate.
				Re: Buying Bits
				Posted: Mon Nov 09, 2015 9:39 pm
				by BearCreek Majors
				Billy, is yours a two piece round one, I believe I have run across these before.
Pat
				Re: Buying Bits
				Posted: Tue Nov 17, 2015 11:35 pm
				by billy
				Hi Chaps,
Sorry I didn't get back to you...
Yeah mine is a in two have like a split washer. I have read that it was either or, so I'm thinking the horseshoe *might* fit. Although it wouldn't be correct.
				Re: Buying Bits
				Posted: Wed Nov 18, 2015 9:22 am
				I have a feeling that, way back in the mists of time there could have been a two piece washer but Henrietta, September 1953, with the original front plate and timing cover without dowels, has a horse shoe one. There is no mention of one in the parts book or workshop manual/service letters either and all references start at 1952. So it is a bit of a mystery but I wonder if it was used in the truck application.
However, the horse shoe washer will fit and be OK, it is only that shape to get it over the camshaft. Just make sure your block has a locating hole for the tab.
				Re: Buying Bits
				Posted: Wed Nov 18, 2015 11:47 pm
				by billy
				My major is a 53 one as well.
That creates a bit more of a story I guess.
Yeah the split washer has a pin on the top part. from looking at the dirt marks on the block it appears that the washer has been broken for sometime, there is very distinct marks.
so the horseshoe from say agriline alright to use?
				Re: Buying Bits
				Posted: Thu Nov 19, 2015 9:24 am
				Yes, should be fine.
