				Power steering pulley
				Posted: Wed Nov 25, 2015 6:12 pm
				by Spicklas
				Does anyone have a pulley for original power steering for a major? I have all the other bits and pieces (except for hoses which is not an issue), but cannot seem to get my hand on a pulley. It seems I have to have one made, but I need help in getting the right dimensions. Is there anyone on this forum that can help me?
				Re: Power steering pulley
				Posted: Thu Nov 26, 2015 5:31 pm
				by Kjetil
				You need two pulleys? One on the pump and one on the main shaft
Early next week I will be able to some measurements for you.
Probably have to remind me by sending a message
				Posted: Fri Nov 27, 2015 5:34 am
				by Spicklas
				I only need measurements for the crankshaft pulley, I already have the pump pulley. Thank you kjetil, that would be very nice of you!
				Posted: Fri Nov 27, 2015 11:49 pm
				by super6954
				Hi Spiclas
                Just a quick question from your comments, I see many of those original Fordson kits for sale in on line auctions. They don't usually include the special power steering only type water pump with the altered fan flange and pulley on them, and when guys scrap the tractor they don't realise  the kit needs it
 . Do you have that in your parts kit, I'm not sure if thats what you're referring to as a pulley you have or not. If you don't have that correct  pump with that alteration or an old pump you can rebuild with it  you got to find one to make the kit work. There are no repro's available from what I know, and many guys with incomplete kits want them, so guess the price for a rare new or used one
				Posted: Sat Nov 28, 2015 7:53 am
				by Spicklas
				Hello! Yes, I actually found a new old stock water pump for power steering models on ebay a year back, so that*s no problem. The problem is that i can't find a crankshaft pulley for original power steering, since it has a pulley of its own.
I have the special water pump, the power steering oil pump, the ram (which has been reconditioned) and the pump bracket (which I found on ebay that was made as a repro). What I still need is the crankshaft pulley, the two spring clips on the ram, the bracket which bolts to the frame rail and the back of the ram, and the hose connectors between the pump and the ram. I will post the info here when I find the correct hose fitting if someone else sometime need to replace them. I'm no expert in hydraulics, but I believe they are male 5/8 unf male connectors with a 37 degrees inverted flare, they are not available in every hydraulic shop anymore.
				Posted: Mon Nov 30, 2015 9:47 am
				by Kjetil
				I found a pulley. Large diameter 138 mm, Width = 29 mm, Small diameter 65,6 mm.
Bolts on with 6 small bolts, I guess this bolt holes are ready in your existing crank pulley
Bolt circle diameter: 79 mm
I don't know how similar to the original you want to make the pulley, but I can take a few photos.
Don't have a camera here, but possibly to the weekend
I cant guaranty this is an original pulley, but I bought the pump and this pulley a few years ago
				Posted: Tue Dec 01, 2015 5:39 pm
				by Spicklas
				Thank you very much Kjetil! I you have a possibility at some point to take photos of the pulley, that would be much appreciated too!
				Posted: Wed Dec 02, 2015 10:24 am
				by Kjetil
				I don't belive the pulley I have is of the original type, or at least not installed as original.
When I looked into the Part List, a washer is missing, E1ADKN-6332-B
From the part list it seems to be a large washer
Also the two pulleys I have, is connected with 6 off 1/4" UNC screws
When I should put it together after measuring the pulley, I noticed the holes were drilled not symetrically,
and some of the holes were also oval to fit the treades in the other pulley.
Seems very home made and unprofesional. Almost as I should have made it my self.
Anyway, if you still wants pictures, I can do that
Kjetil
				Posted: Wed Dec 02, 2015 11:29 pm
				by guduell
				My pulley on my selene has hole diameter 25mm and outer diameter 145.mm (The latter i just became unsure of as it was one hour since i measured will check again...)
It is held by the big nut and rotation i secured by three flanges on the back fitting between the studs on the other pulley, which also has the six holes.
Front side:
Back side:
Thank you for mentioning about the longer water pump. I saved mine now.
				Posted: Thu Dec 03, 2015 7:56 pm
				by Spicklas
				Thank you for the pictures guduell! I believe you have the original pulley that came with the tractor. Will start searching for a pulley that could be modified into something like yours. Still interested to see pics of Kjetils pulley too if it's not a big problem.
You should save the longer waterpump, guduell. Original water pumps have to get modified to fit the power steering tractors with a spacer between the pulley and the fan blade, otherwise there is no room for the power steering belts etc. But original is way better, as usual.
