				FPM  PTO oil seal number?
				Posted: Wed Mar 02, 2016 4:02 am
				by RH
				Good evening all,
Just wondering if anyone has a part number or oil seal number for the Power Major PTO??  (Canada if possible)
Took the old one out as it was leaking a bit, and it had two thin ones fitted...
Any help most appreciated!
Richard.
				Re: FPM  PTO oil seal number?
				Posted: Wed Mar 02, 2016 9:47 am
				If you are looking at the seals in the PTO housing beneath the gearbox two seals are normal in the later tractors, one seal lip should face towards the gear box and the other towards the rear axle. I would take the seals to a seal supplier and get him to match them, they would be a lot cheaper than ones from CNH.
				Posted: Wed Mar 02, 2016 2:31 pm
				by RH
				Brian,
Thanks for the reply, but I am meaning the seal for the PTO shaft at the rear of the machine.
I think this was a fairly wide oil seal, but two thin ones had been stuffed in there instead.
Richard.
				Posted: Wed Mar 02, 2016 4:17 pm
				by SkidRoe
				Hi Richard,
See the link below:
http://www.malpasonline.co.uk/itm/PTO-S ... Seal/65670
Dimensions are 2.5" O.D. x 1.5" I.D. x 0.73" W, double lip seal.
HTH - SR
				Posted: Wed Mar 02, 2016 4:42 pm
				by RH
				Thank you SR!  That's perfect!
Richard.
