Power major gearbox getting hot
Posted: Sat Aug 20, 2016 10:22 pm
I have a Fordson power major in which after running for over an hour on the road the gearbox housing becomes very warm to the point where you can only just keep your hand on the gearbox housing. I am aware of handbrake problems with majors where I have been told the friction plates lock on if the handbrake is left on and I can assure you I did not leave the handbrake on when using it and it seems as that is not the issue as I can push the tractor backwards and forward easily and the tractor does not seem that it is under load when pulling away. I also tried the tractor on a pto saw bench the other night to see if the gearbox had the same affect in which it still heated up but I did not think it heated up as much as using it on the road. The only other cause of the problem I thought could have been a bearing worn in the gearbox although I would have thought I would hear that. Would really appreciate it if you could tell me if all majors are the same and run warm or if I Amy have a (another) potential issue on my hands.
Many thanks
Dan
Many thanks
Dan
