Bolt Locking Plates
Kjetil
Bolt Locking Plates
Post by Kjetil »
On the flywheel, front engine plate and elsewhere, Ford used bolt locking plates or tab washers for locking the bolts.
The Repair Manual tells new bolt locking plates to be used.
What is common practise?
New or reuse?
Are New bolt locking plates available, and if yes, where?
Thanks for any help
Kjetil
Re: Bolt Locking Plates
I just put the old ones back, to be sure a little loctite won't hurt.
Rgds
In the UK Agriline appear to do the Dexta tabs but not the Major.
However, in the Netherlands is a company called Histoparts, they do the main bearing locking tabs and the flywheel locking tabs.
histoparts.com
Telephone +(31) 514 58 19 16
oehrick
Post by oehrick »
They are not difficult to make if your old ones are past use and you cannot find replacements, old desktop computer case steel is ideal for this sort of thing.
