Fasse valve for SM to run 4 Hyd lines from JD 335 Round Baler?
lakebilly
Post by lakebilly »
I bought a JD 335 Round Baler & it has 4 lines from baler to tractor. My Super Major (63) has only two lines.
What do I need to utilize the 4 lines?
Also how to wire bale indicator? where to look for wiring schematic?
63 Fordson Super Major "Babe", 1953 Jubilee, IH 656, Ford 961. Farmall H, Kubota 3430
FB pic page of tractors; https://www.facebook.com/pg/Unkle-Sonny ... 2873587074
Re: Fasse valve for SM to run 4 Hyd lines from JD 335 Round Baler?
First you should find out whether your JD baler is set up for a closed center or open center hydraulic system on a tractor.
When open center, then a valve chest with more spool valves can be set up and connected to your original hydrauclics. You should althoug find out whether you need 4 single acting, 2 double acting of 2 double and 2 single acting.
Might be a super has a little bit to little oil flow to get things running really smooth.
Will you have enough HP for this?
lakebilly
Post by lakebilly »
Thanks for replies. Completely swamped w/too much to do. instead of researching, I bought a tractor w/4 remotes (656 International). Sorry I didn't reply sooner. thank you for your input.
