Headlight wiring
Headlight wiring
Planning ahead a little, I'm a long way away from fitting lights yet, the wiring for the rear lights is present but not usable and will need to be replaced, but the front lights, horn and associated wiring is long gone. What is the route the loom should take?
If it works, leave it alone.
Re: Headlight wiring
Thanks Henk, I'll take a look.
Found the wiring, it was tied in a knot and stuffed behind the starter.
I think that's what caused the short circuit.
