FSM CLUTCH COVER ASSEMBLY
kissamo
Post by kissamo »
DEAR enthusiasts;
I ordered a clutch for My FSM. I opted for -Clutch Cover Assembly - Single 13". I later noted that also -Clutch Cover Single - 11" is for FSM.
CAN any of the clutch cover be fitted at the flywheel of FSM. I DONT KNOW WHICH ONE IS FITTED IN MY FSM BY NOW.
ANY CLUE ON THIS
BEST RGDS
ELIAS
Re: FSM CLUTCH COVER ASSEMBLY
Hi Elias,
11” is standard fitted. 13” on heavy duty applications. This one might need an other flywheel.
Most FSM in Europe are fitted with a dual clutch. Which had another gearbox, another type of clutch and another Flywheel.
Regards emiel
The 13” needs a different flywheel with 8 instead of 6 mounting holes.
Rgds emiel
A 13" clutch has a screw cap greaser on the gearbox RH side, the dual clutch enables the PTO to work and gear changing simultaneously, with very noticeable dual pressure points when pressing the pedal (assuming the stop pin is not in the upper position).
yes,
the grease nipple on the RH side is the trick to find out it's a 13" clutch
Here is a picture of the cable for the grease nipple
