Rare (I think) battery clamp
Here's some pics of Billy's battery clamp, the one used until 1956. It has had new plate added as a result of corrosion from batteries spilling electrolyte. As a result of this, the clamp will be coming off soon to get some paint on it (pics coming soon).
Old52
Re: Rare (I think) battery clamp
Post by Old52 »
That looks the same as the one that our old '52 used to have. I took it off some time ago as it was too close to the battery posts on a replacement battery and now don't know where it is....hate to say but it probably went in the bin! I don't have anything on it now, as it never sees any real speed and therefore no big bumps.
Cheers, Bob
The petrol one is smaller, the diesel battery requires removing the bonnet to get it in. Here we're on rough ground, so it's definitely needed. It does get close to the poles, but if you insulate them and keep the clamp tight you should be ok as nothing moves. It fits better with the original type connectors (pic coming when ours is sorted, we only have Billy's negative one) which don't have bolts sticking out.
fenhayman
Post by fenhayman »
I think that type of clamp was used on early diesel majors with 2 x 6 volt batteries.
This clamp is definitely for a single battery, although it's quite possible that the twin batteries came before the new tray and clamp with three rods (two at the ends near the middle and one in the centre) in place of this one with four rods round the edge (one of Billy's ones is lost, but with plenty of unknown mounds of stuff here we might well find it burried somewhere). I think the early arrangement wouldn't hold the twin batteries too well.
Here's a good pic of the twin battery clamp from eBay.
https://www.picclickimg.com/d/l1600/pic ... attery.jpg
Please say when the link fails, as we'll need a copy in order for it to remain visible.
I looked up the part no again ont he cnh website. It is #81784828 and listed for the fordson tractor 01/53 - 12/64 in the engine section under frame, exhaust system and battery clamps.
It is a modern part no, although no units on stock according to the website.
Rgds
If you look at the description it says it's the twin battery clamp, it matches the one in the latest parts book.
Thought I would show Super Billy's clamp too, this one actually came with our half Super Major and was modified (somebody cut it and overlapped the middle part making it too narrow to fit even the current batteries, not to mention an original one), I've spent some time trying to return it to more original spec with some false starts and unable to sort some areas.
It does at least do its job now but it still needs work.
Just found this:
https://files.klaravikcdn.com/uploads/productimages/85/3e/984132/extrabilder17706890_large.jpg?v=1654685379
Came from here:
https://www.klaravik.se/auktion/produkt ... ajor-1952/
Serial 1224581, April 1952.
I don't think I'd seen one before, quite a few good details on this tractor, the page has good views of many Fordsons.
I've looked at the parts book and thought the numbers might be of use.
The one we have here is E1ADDN-5165, attached by 4 rods (E1ADDN-5155). The twin battery one is E1ADDN-5163C, attached by 3 rods (E1ADDN-5155B, E56-NA-9, E1ADDN-5164). Big batteries will fit E1ADDN-5163C if E56-NA-9 is left out, but I don't recommend it. Spark ignition tractors used E0A-5165A till 54 then E1ADKN-5165. Tractors without electric starting use 402E-5165B. All these smaller ones use 2 rods (E1ADKN-5155). Inertia starters were introduced from 1507517, such tractors will have a smaller battery, and worth considering for ordinary tractors without using a full size battery (thinking of what aftermarket companies offer here).
