FSMD change + gound to - ground
FarmallM51
Post by FarmallM51 »
1962 FSMD with original generator & voltage regulator. All of my other tractors are negative ground. Can I just change this from + ground to - ground without changing anything else in the generator/regulator system? Thanks.
Marlin
Re: FSMD change + gound to - ground
No. Not difficult though. You'll need to 'Flash' the dynamo to repolarise it, and from memory the ammeter will work back to front. The starter will repolarise itself.
If it works, leave it alone.
