Super Major - Injection pump driveshaft seal
Posted: Mon Apr 28, 2025 5:44 pm
by Bluebilly
The driveshaft seal is leaking badly on my Super Major new performance. Can someone tell me what is involved in renewing it?
I'll do some research, but its alway good to hear from someone with first hand experience
Re: Super Major - Injection pump driveshaft seal
Posted: Mon Apr 28, 2025 8:08 pm
by mathias1
the injection pump and coupling needs to be removed. It should be possible to pry out the seal from there
I'm not sure, but the seal size might be different on the NP super major
Posted: Mon Apr 28, 2025 10:19 pm
by Billy26F5
I'm assuming you mean the auxiliary shaft, the seal was the same throughout (E1ADDN-66610A). As Mathias says remove the pump and coupling and pull out the old seal (self tapping screws can be handy for that) then fit the new one. Make sure you check the timing is ok on reassembly and that the bolts are tight.
Posted: Tue Apr 29, 2025 9:02 am
by Bluebilly
Yes, Its the auxiliary shaft and I'm hoping its not damaged since removing that seems to be a bigger job
Thanks to you both for the advice, I feel a lot happier going ahead with it now
