Engine front mounting plate for Industrial Engine
Posted: Sun Dec 07, 2025 9:28 pm
by Kjetil
I have an Industrial engine, s/n 554163, with an industrial typen front mounting plate.
I have seen some brackets that can be added to the front plate, that fits the tractor frame.
Anyone know if they can be purchased?
Alternatively having a drawing, so I can have someone to make a set.
Link shows photo of the right hand side bracket
Thanks for all help
Kjetil
Re: Engine front mounting plate for Industrial Engine
Posted: Mon Dec 08, 2025 6:09 pm
by Billy26F5
Those are part nos 591E-6060C (RH) and 591E-6031C (LH). Can't really help you there, you could try to measure it off a tractor plate and this one. Early mid August 66 engine. You could always swap it with a tractor one too. This one is 591E-6030B, corresponding to E1ADDN-6030A.
Posted: Sat Feb 07, 2026 7:23 am
by Kjetil
Thanks for your response.
My engine is an diesel, so I belive it is an 592E.
The part nos you specified is for an 591E 4 cyl Petrol, but I assume they may be identical for both diesel and petrol.
Where did you find these part numbers?
Is a part list available for the industrial enginees?
Regards Kjetil Grytnes
Posted: Sun Feb 08, 2026 9:37 pm
by Billy26F5
Your engine is a 592E, but as you've already guessed many parts fit all of them, as is the case here. I've got a parts book (owner, September 63), hoping to find a dealer one soon (plus loads of other stuff!) and I sent Henk a copy, although he's a bit busy at the moment. Hope he gets there soon, there's a lot of extra stuff I've already got which will end up on the FFCN. A large proportion I've never seen at other times, just got it as it happened to be around, with really interesting details in all of it.
