Here is a photo of my tractor's engine, taken over a year ago:
Here is what it looks like after being "dry-fitted." Meaning, I put it all together without any seals or gaskets, just to make sure that I haven't misplaced any parts:
This is a photo of the chassis, which shows the front end, sitting on the box that contained all of my parts as I cleaned and painted them over the past year:
I am now working on the double-clutch and the rear axles. Here is a view of my "old-style" axle:
Note the retainer:
The newer axles have locknuts instead of pressed on retainers. My question is, do you think simply replacing the inner oil seal will suffice to keep rear-end fluid from seeping past the outer seal and onto my new brake linings? When I got the tractor, the brakes were saturated in fluid.
I've read the Shop Manual, and it is a daunting task to split the old bearing and seal retainer, then heat the new retainer and refit the new parts. I can take it to a machine shop if necessary, but if you think the inner seal will work by itself, I'd rather go that route. Or, is there another alternative, like the Sure-Seals that are used on Ford N-Series tractors?
Here's the link to my Dexta Part II album, with additional photos of of the painted parts. You can check out Part I for more pictures of the teardown process:
http://picasaweb.google.com/tractorNstu ... ationPart2#
Don
