Leaking oil timing housing gear
My dexta is leaking oil (when the motor is running) between timing housing gear and block on the right side (looking from seat to front)! Is it possible to remove the timing housing gear from block without disassembly the motor from tractor? Please I need advice!!!
Dunggatherer
Yes that is possible.
Just support the tractor with wooden blocks under the engine.
Then remove the whole front axle,cradle complete with radiator.
Take off the waterpump.
Then the pulley and you can remove the timing housing.
And if you check the pictures in the posting about engine timing by Ddoan you can see what it will look like.
Good luck!
Rob.
Good luck!
Rob.
