Hi everyone!
Looking for some help restoring a super dexta.
The plate that is bolted on the back of the engine for holding the air filter can and throttle linkage there is a s shaped bracket that bolts on behind the air filter to the head the question i have is the air breather pipe from the rocker cover the bracket that holds the pipe is it bolted behind or on top of the s shaped bracket?
If somebody had a picture or the answer that would be great.
Have you seen the parts list downloadable from www.fordson-dexta.de ?
Reference to this might answer your Q, or at least enable others to understand your Q more clearly.
All the best
Yes on the parts book page 56 item 62 s shaped bracket bolts on to side of head with 2 bolts one of the bolts also holds the air breather pipe of the rocker cover my question is it behind the bracket or on top.
Thanks again.
Put the parts book does not show view of right hand side of engine what i need to see.
Will take a picture tonight and upload it to show what i am talking about.
