Gasket differencial house and rear axle
Has some make the gasket between differencial house and rear axle bij his own? What gasket thickness must I use? I have asked New Holland compagny it is no more to deliver they say! Are do you use liquid gasket? Please give advise!
I don't know if you can buy them any more, and if I recall correctly the thickness is changed to set the end float on a bearing in the diff. Check the manual at the address below.
http://www.fordsontractorpages.nl/manuals.htm
Also try here http://www.fordsontractorpages.nl/phpbb ... php?t=2382
I asked about the diff pre-load but to be honest, these machines are so old I doubt they're worried about pre-load in thier diffs anymore. I'm just pleased I no longer have 20 litres of oil all over the floor!
