cylinder head
cylinder head
Hi, could someone tell me if a58 standered dexta cyl head will fit on a super dexta, also if there is a different head gasket for both type,
Gerry
Gerry
Hi Gerry
When researching my cylinder head replacement I came to the conclusion that the cylinder heads were the same
I would expect the head gaskets to be different due to the larger bore on the Super Dexta but, the spares suppliers dont reflect this.
Thanks for your quick replies russelm an bensdexta, that is just what i needed confirmed as iam thinking of bidding on the one on ebay , it says its off a64 superdexta but the moncyl and cast numbers on the head in front of injectors are not on my s/dexta head but are on the 2 earlier heads ihave on my standered dextas, ill probly make abid now,
thanks again Gerry
thanks again Gerry
A cyl-head of a STD and as Super are the same.
The gasket is different (hole diameter of the piston). You can put a super-gasket on a standard but not the other way round. I even doubt that a gasket for the standard is still available.
Rgds
Jos
Jos
It probably will be Gerry, I have fitted heads in the past where there is some pitting.GERRY wrote:HI russelmi i asked the gay about this and he says he has been asured that this is ok and wont affect the head . he seems adecent sort ,hope im right , Gerry
My only worry is if they will give stress riser points which could encourage cracking (and as my original head is cracked I am infering that maybe the Dexta heads are a little prone to it)
