first post ! lol
questions .. issues with my s dexta ..
i,ve had a search on here for ideas ..
i have a internal leak on my hydaulics. arms drop from the rased persition un till system corrects , set in position control ,prob only 8 - 10 seconds between corrections, if i pull out the auxilary knob it stays up alot longer - prob 8 minutes with a 2 f plough, engine swiched off .
check valve leaking ?
how much damage on the check valve ball for it to leak ? mine does have rings on it , but very minor ??? the seat looks ok .. i think .
the main control valve, i think is ok , nice snug fit , the unloading valve seems fine .....
all systems had a, good clean , new seals return filter ect.
i have problems tryna get the qualicontol settings to .. my turn buckle wants to be longer to get the 10 mm setting and i honestly dont know why .
thanx in advance , tom
