Would it have had a Fordson badge or similar down the side of the bonnet? cant see any holes where one might have been fitted? just want to know if I should put one back on or not as I thinI do have one from spares kept from tractors I have broken last year.
Same question regarding the number plate bracket on the rear axle. The number plate light is there, and the number has always been painted on the rear housing. In my pile of bits I found a bracket that fits opposite the number plate light, that would support the other end of the number plate. Would it have been there originally, or was this a later addition?
And finally the seat pan.
Can anyone tell me if this is the original early seat pan design, or if my father or grandfather changed it some time since they bought it.
I was going to junk the worse pan and put on a better one, so repaired the better one, went to fit it and noticed that the one on the tractor was different.
I have now repaired the one that was on the tractor as well, so have both, but would like to put the correct one back on.
Oh, off topic....was there a clear out of the old forum user database? Just that I have had to re-register this morning. I have ben away for a while, and have not checked the forum for a while now, so probably missed any system /admin messages?
Neil
Note ridges down side, no remains of X shaped moldings /ribs, and note the mod under the seat, that helps support the old broken seat, and also is a useful second tool box for toplink pins etc.
Next to the better one of different design with moldings
