Leveling box thrust bearing
Mervyn Spencer
Post by Mervyn Spencer »
Good morning Chaps
I am busy restoring my leveling box and had to replace the thrust bearing which was kind of worn. I made the usual mistake of not taking note of how the thrust bearing was origanally placed and am now confused :? :oops: as to which way round it should be positioned. Pleeeeease can someone advise.
Kind regards
Mervyn
Mervyn Spencer
Worked out how the thrust bearing should fit/lie. Quite obvious when you have a second attempt.
Kind regards
Mervyn
