Hi There
Being new to this I am struggling a bit trying to start attaching images to my posts.i reckon I am almost across the line but getting stuck last step. I read a previous post by bendexta and got onto the tractorsearch link. I then managed to find my jpg image as local off computer and size at 640 and press upload button. This is where I am running into trouble with the last step. What exactly do you need to copy from here and paste into your post? Secondly when you do a preview does it show your image or only the link letters to the author?
I would rather play with tractors than computers!!!!!
Bradson
Attaching Image to a Post
Re: Attaching Image to a Post
You need to copy the [img] code in the box below the image on treactor search. If you do a 'quote' on any post on here with an image, you will see how the [img] code should look.
hi
i use photo bucket
then u just copy the IMG code .
but i think there are lots of other sites too.
i use photo bucket
If you use tractorsearch, or indeed photobucket, after you're uploaded your photo and it displays, look in the boxes below it. One of the boxes contains the [img] code, copy & paste this into your post on here. Preview shows your post exactly as it will appear, pic & text.
