Hi Gerald
I did what you suggested with a screw and nut and two washers, I definately could have done with a second pair of hands but I persevered sweat running all over with a 36 degree day and 60 watt lamp in you face, it looks good, thank you.
I filled the filter with some paint stripper and let it for about an hour then washed it out thouroughly and it also now looks super clean.
Thanks you also for offering me one of your filters, most kind of you.
PS. Gerald, please can you confirm for me whether the bottom of the filter is left open or is there something missing on mine. There is a little flange on the bottom with a tiny hole through it, maybe something should be attached to it
Kind regards
Mervyn
