I am about to replace the temperature gauge on my Dexta. Can anyone tell me what "route" the cable takes from gauge to probe?
Temperature Gauge
Re: Temperature Gauge
down through the fuel tank, alongside steering collumn
Thanks for your reply
You will prob find the cable is 'too' long.
Apparently that is so you can split the tractor without removing the temp probe. So lose the excess under the fuel tank, but make sure it can stretch out if you need to split her.
And beware as not all the repro gauges actualy fit properly
Yes you want one that fits inside the bezel - a lot don't unfortunately.russelm wrote:And beware as not all the repro gauges actualy fit properly
