Morning all
Handbrake on my super Dexta isn't staying on
It seemed fine when I had the mudguards on, but now I have swapped to the cab ( I can't remember the make, but it has canvas roof and doors ) it won't stay on
Is there a different model mechanism for the cab or might it be knackered and replacement needed - if so, which bit or do I need ratchet, rod, spring, pawl and all ?
Many thanks in advance
Hand brake malfunction
Re: Hand brake malfunction
I had a similar problem when I fitted a new handbrake to my Dexta. It took a few attempts to get the angle of the toothed bracket correct so that the pawl didn't slip. I had to make the holes in the mudguard oval to get the correct adjustment. You may have the same issue if it was working ok before you changed to the cab.
Grey Fergie
Ford 2000 - Pre-force
1958 Dexta
Roadless 75
MF35 Industrial
MF135 Industrial
MF135 multipower
MF 165
MF 240
MF 360
MF 20E - Industrial
MF 20B - Industrial
MF 20B - Industrial with 7 gang mower
SAME Solar 60
1958 Dexta
Roadless 75
MF35 Industrial
MF135 Industrial
MF135 multipower
MF 165
MF 240
MF 360
MF 20E - Industrial
MF 20B - Industrial
SAME Solar 60
Thanks mate !
