Dexta -60 project
Tubal Cain
- Site Expert Team
Re: Dexta -60 project
I suspect that the reason that the glow plugs are failing is due to the fact that the tips are in the spray/flame path of the injectors!
In this instance the plugs are nearly at right angles to the injector, whereas in engines which are designed to be fitted with glow plugs the angle between the plugs and the injectors is smaller and one can assume that the tips are not directly in the spray path.
Gerald
Gerald
dexta roadless
A little update
had time to investigate the system today. The glowplugs are perfectly ok. The only reason they didn't work was a bad connection due to rust on syl no. 3 were the cable comes in. The plugs have been in there for 4 years now, so the conclusion is that they survive this very well
6o Dexta Roadless
62 Dexta
63 Super Dexta
75 Shilter UT
62 Aebi
62 Dexta
63 Super Dexta
75 Shilter UT
62 Aebi
Broadspeed
Broadspeed
Agriline parts arrived and a little progress with the engine
Oil pump didn't need any mods..
Dexta -60
Dexta Special -64
Dexta Special -64
Broadspeed
Rest of the tractor moved inside and washed properly. Today I will fit the engine and front axle back
Dexta -60
Dexta Special -64
Dexta Special -64
im interested how you are going to do the peddle throttle
Owner of a 1961 fordson dexta restyled model
Broadspeed
It will come on time
Todays assembly:
New bush:
New axle:
Next will be the paint
Todays assembly:
New bush:
New axle:
Dexta -60
Dexta Special -64
Dexta Special -64
You are really putting some work into that thing. Going to be better than new when your done
Chris
Broadspeed
Broadspeed
Excellent work, and you're getting on fast....
I just noticed your front wheels and I'm wondering if they are original?
I don't recall seeing split rims on one of these tractors before.
Chris
Broadspeed
No they are not original. They are some previous owner's installation.. Somebody said in the Finnish forum that they are from horse powered trailer
I found original wheels but they are still missing tires..
Next I have to start to assemble the electronics. New wiring harness will need some mods because of new alternator..
Dexta -60
Dexta Special -64
Dexta Special -64
Broadspeed
Assembly
Main switch
Fuel tap overhauled
Oil pressure gauge
Test run
Main switch
Fuel tap overhauled
Oil pressure gauge
Test run
Dexta -60
Dexta Special -64
Dexta Special -64
Broadspeed
Superb work you've done on your tractor.
I see you still have plenty of snow!
Broadspeed
Yes, plenty of snow and it's raining more all the time.. And of course Dexta is not ready for work yet
Dexta -60
Dexta Special -64
Dexta Special -64
I am really enjoying this build up and restore. I know how much effort you putting into this project and your rewards will be plenty. I also appreciate all the photos you are posting. Its a pain sometimes to remember to not only take the pics, but upload and resize ect.... Well done and thank you so much.... Your pics will help others when their Dextas get their turn at becoming new again....
dave
dave
1964 Super Dexta, ol'Blue
Broadspeed
When I start a project I like to take lots of pics, because one picture tells more than 1000 words
Especially pics taken while disassembly are useful when you are putting all back together.
Dexta -60
Dexta Special -64
Dexta Special -64
Broadspeed
Little bit more test drive
Now I have to go to work trip for about 2-3 weeks so this project won't make any progress
Dexta -60
Dexta Special -64
Dexta Special -64
Broadspeed
Work trip delayed a bit, so I had a time to paint rest of the parts
Throttle pedal version 1. Not beautiful, but works
Throttle off
Flat out
Throttle off
Flat out
Dexta -60
Dexta Special -64
Dexta Special -64
Broadspeed
Little progress again
Did already some snow clearing
Dexta -60
Dexta Special -64
Dexta Special -64
What is the bracket under the PTO?Broadspeed wrote:
Great work!
