I can show a picture of the links at my Dexta, who was brake down at the start here, and I,d made a new link system of two pice of some old braketube,s and steelpin who fit insides the tubes. and whit a spring...it work good together with the handthrotle and footpedal then.
Ah! So the hand throttle sets the 'lower' throttle position. Then pressing the foot pedal increases throttle from that lower position When the driver lifts his foot, throttle returns to the lower (hand throttle) position? That is clever!
Today it arriwed my second set of halftrack, and it was only alitle surface-rusty on it, this set is,nt run more than mybee 50 houres, and every parts was there, (so for now I also can put the first set on my "57 goldfish" in the future, I think), and with new tires and Ford grey color on, I think it will be ok.
ps; I will show moore pictures while assembling next winter.
And here is the tractor to my youngest brother, he got it when it was neerest a wreck... but he has now got the engine running, split and repaired the dual clutch, and mybee he will start some moore resto at the litle tractor too... I hope.
This is a pickup hitch produced to most Dextas after 1960 in Norway. Infact at least all up to mid 80s the Fords came to Norway without, and the dealers mounted on a norwegian as it was deliverred. My Dexta from around Jan 1960 has a different one. You can see some of it here
6o Dexta Roadless
62 Dexta
63 Super Dexta
75 Shilter UT
62 Aebi
Thank you all for nice comment,s - (the swandri guy)-yes, I think you will also get your dexta even nicer if you want... Yes Ben it is a better simplier and good pickup hitch, as Magne Olav says too, I think better then the "threepoint pickup" hitch for the old fergies. It is also good and steady, but alot moore work to change over for differents euqipment,s.
-Så...Magne Olav, har du fått nok snø til roadless,n din??
mikkel
We have got some snow so I have beeen able to test it and wreck my snowblower shaft . But fortunately I managed to weld it together again. I found this snowblower on a scrapyard 21 years ago.
6o Dexta Roadless
62 Dexta
63 Super Dexta
75 Shilter UT
62 Aebi
