Haven't painted the hitch yet, so it's still missing
Dexta -60 project
Broadspeed
Re: Dexta -60 project
It is the locking lever for trailer hitch.
Dexta -60
Dexta Special -64
Dexta Special -64
A close-up photo when it's finished would be great!Broadspeed wrote:It is the locking lever for trailer hitch.
Sorry for hijacking a topic, but that vertical exhaust that goes outside seems just what I need, is that using a non standard exhaust?
Broadspeed
Exhaust manifold and muffler are both original. The pipe between I made from standard 2" thick wall steel pipe and 2pcs 90 deg curves
Dexta -60
Dexta Special -64
Dexta Special -64
Broadspeed
Now there's a new front tyres.
While picking up those tires I saw a -63 Super Major with engine problem and I bought it
http://www.fordsontractorpages.nl/phpbb ... f=2&t=5008
Dexta -60
Dexta Special -64
Dexta Special -64
You have a bad case of Fordson fever!While picking up those tires I saw a -63 Super Major with engine problem and I bought it
Chris
That's a universal rim. Originals had only 6 bolt holes and 4 square holes for the weight bolts. However it will do the job fine.Broadspeed wrote:
Broadspeed
Yes. And it seems to get worse. Now I am looking for a Super Dexta project, but it is very hard to findCvans wrote:You have a bad case of Fordson fever!While picking up those tires I saw a -63 Super Major with engine problem and I bought it![]()
Yes, You are right. I haven't thought about that beforeBensdexta wrote:That's a universal rim. Originals had only 6 bolt holes and 4 square holes for the weight bolts. However it will do the job fine.Broadspeed wrote:
Dexta -60
Dexta Special -64
Dexta Special -64
Broadspeed
Now only wiring harness and fender lights are missing
My friend made those stickers to the engine covers. I had to buy this without any test run, but luckily the hydraulics and transmission works perfectly
Dexta -60
Dexta Special -64
Dexta Special -64
Looks very nice.
Good to hear that everything works the way it is suppose to also.
Chris
Very nicely done friend.... Its so good to see another Dexta put back on the farm.....Thanks so much for all your hard work and pictures.....
1964 Super Dexta, ol'Blue
Broadspeed
Dexta -60
Dexta Special -64
Dexta Special -64
I need to find an old 1 1/2 ton truck to do that with. Great idea and thanks for posting the photos. It surprises me that you have the oil capacity to operate that large of a cylinder.
You have less snow than we do. That's unusual.
Chris
Broadspeed
Yes this kind of old trucks "abuse" is very common here
And there is no problems with oil capacity
Only thing with that trailer is to move the axel backwards as much as possible. Otherwise it may flip over when you use the cylinder. How do You call that mechanism btw?
I live in southern Finland, so almost all the snow is gone. Northern Finland still has snow up to 60 centimeters
Dexta -60
Dexta Special -64
Dexta Special -64
Around here it is known as a hydraulic hoist or hydraulic dump. Either way they sure beat a shovel.
Chris
Broadspeed
Dexta -60
Dexta Special -64
Dexta Special -64
Was your dexta original a downswept? Since the way you have put your exhaust and no hole in the bonnet?
Owner of a 1961 fordson dexta restyled model
Broadspeed
I think most of the Dextas imported to Finland was equipped with downswept exhaust. But also most of them have been modofied to upswept
Dexta -60
Dexta Special -64
Dexta Special -64
Nice work on the forks. I envy you being able to go out and cut wood. I used to really enjoy that in the fall. It's also good to see you putting your tractor to work and using it for what it was intended for. Half the fun of owning one of these tractors is getting it dirty.
Chris
Broadspeed
Indeed!
I really enjoy using these old great machines to work too. In Finland we also call these old machines as a "therapy tractors"
Dexta -60
Dexta Special -64
Dexta Special -64
Broadspeed
Dexta -60
Dexta Special -64
Dexta Special -64
Broadspeed
Forum would follow from Turkey. I have a 1964 model Dexta. I am following with interest your presentations. Your tractor is very nice. Use it in good health.
Fordson Dexta Model : 1964
Engine No: 154**49
Serial No:9007**
Engine No: 154**49
Serial No:9007**
