how to get shifter spring back on?
Posted: Mon Jun 15, 2009 6:04 pm
(Ok, i'm sure I must just be looking at this all backwards, this has got to be something simple.... but anyways...)
I had to remove the shift levers and cover from the transmission since one lever had popped out of position. I'm trying to reassemble everything now but I can't seem to figure out how to get the spring back onto shift lever??
It's the spring that sits on top of the dust/grease "cap" (looks like an upside-down funnel) and is held in place by a thick C-clip on the shift lever. All the pieces are back in place but I just can't seem to squeeze it down far enough to get the C-clip back on!? Is there some special tool I need? Has anyone does this before and have some neat trick??
Thanks,
Dan
Thanks,
Dan
