I had managed to get the pivot pin retaining plate off in the dark earlier this week. A torch, spanner, lump hammer and chisel and still manage to keep most of my fingers intact! The pivot pin was well and truly stuck though.
The birthday party finished a bit earlier than I thought so I slipped into the barn while it was still light and decided to drop the bracket with the central part of the axle still in place. I dragged it into the workshop for further dismantling after the kids went to bed.
I knew the pivit pin would be a pig to remove, so after lots of lubricating oil I looked around for a suitable tool to drift it out. I looked in the scrap pile and pulled out the old top nut of my dexta steering column. It fit inside the pin and has a shoulder that is smaller than the hole in the casting - perfect
After about 20 blows with a lump hammer the pin was pushed out far enough to remove the axle - thats when my luck stopped
What I thought was the spacer between the front of the axle and the bracket turned out to be the remains of the bush that should be inside the axle. So I have no spacer in front, no washer behind and a oval hole in the axle. Its 48.3mm across the horizontal and 49.3mm across the vertical.
So - its now question time
1.) What is the best way of building up the hole in the casting or do I drill it out and put in a bigger bush? I have already bought a new pin and bush in readiness.
2.) Is it worth fitting a grease nipple while I am at it? The front engine seal is leaking oil however the pivot was still very dry.
3.) What are the dimensions of the spacer and washer? I can probably work it out however I need to get the washer thickness corrrect as the radius arms are a fixed length.
Thanks in advance!
Andy
