Lubrication of Simms Injector pump
Posted: Mon Oct 12, 2009 5:14 am
by brownsmule
I understand that there are two different injector pumps for the Dexta tractors. I've read that one or maybe both require motor oil lubrication. Are they lubed by the engine oiling system or do they require individual service? I have a 1961 Dexta and I want to take proper care of all systems. Thanks in advance for helping me out.
Brownsmule in NC USA
Posted: Mon Oct 12, 2009 7:58 am
There are many posts on this subject. To summaries, the pumping elements of both types of pump are lubricated by diesel as it passes through the pump.
Dexta tractors before 1962 had a vacuum governed pump which required no oil in service.
After 1962 both Dexta and Super Dexta tractors were fitted with a Simms/CAV Minimec pump with a mechanical governor. This part was filled with oil and some diesel was allowed to leak into the housing, diluting the oil there. Every time you change the engine oil, you should change the oil in the pump governor.
